Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone SE rear camera issue.
Hei.
Having issue with a rear camera and flashlight not working aswell. The front camera works nicely. The phone has a water damage history. Firstly the pp1v2_camera was missing so made a little jumper from PP1v2 line. PP1v8 line is present, also the i2c lines have 1,79 volts.
Only power what i am missing are the PP2v5 and PP2v85 but these are only present when camera is opened in phone - right ? The diode values didnt showed any short circuit to ground.
Also tried a new camera also - no luck... Any ideas ?
Is dit een goede vraag?
1 Opmerking:
You need to confirm you have the PP2V rails while the camera app is open before you can trouble shoot any further. I know it is a pain trying to measure these. You might have to solder some wires to take the measurements.
door
Voeg een opmerking toe
1 Antwoord
Water damage—-the problem is where the water went. The *most likely* problem here is corrosion at the connector.
Was dit antwoord nuttig?
1 Opmerking:
Hei,
Thanks for the reply. The connector seems OK when looking with microscope.
Does someone have SE rear camera FPC diode reading ? zxw unfortunatley does not have it.
door
Voeg je antwoord toe
Kaspar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 73
