LCD backlight connector issue (darker left side)
Hi all! I have a 27” iMac mid 2011.
It has a known LCD backlight connector fault. I already tried the re-soldering the left side connector but messed up the connection points while soldering the wires to the LCD’s LED backlight board. the connection points on the LCD for the LED’s not holding the soldering anymore ):
So, is there any way around to solder the power cable for the LED backlights from the iMac to connect directly? I couldn’t find any tear down guide for the LCD panel.
Thanks in advance for any bit of help!
Is dit een goede vraag?
3 opmerkingen
Mücahit Kahraman post some good pictures of your attempted repair etc. with your question. That way we can see what you see and hopefully find a solution for your problem. Voeg afbeeldingen toe aan een bestaande vraag
door oldturkey03
Added some photos to make it more clear.
door Mücahit Kahraman
Mücahit Kahraman post one that is zoomed out so we can see the general location of the botched area.
door oldturkey03
