I damaged this connector in the picture below. Can I fix?
I damaged the connector below, is this watch junk, or can I fix. I just put a new battery, force sensor, and screen. Willing to go deep down the rabbit hole!
Is dit een goede vraag?
Score
0
Do you consider yourself doing microsoldering to fix this?
door joshua morgan
I am going to try, I am a very good solderer, have watched a couple video's and I understand the complexity. The LCD flex cable for use with Apple Watch (Series 1 - 38mm) is only 4.00 dollars. It is junk if I don't. I have seen flux used to help loosen solder joints. Is there a certain flux you recommend ? The same with the solder, any certain solder? Any help would be appreciated!!
door Daniel G Farley
