Ga door naar hoofdinhoud
The models of series C, E and F are technologically related. They stem from the Swiss company Eugster Frismag. Similar devices were distributed under the brand names Krupps, AEG f.ex.
6 Vragen Bekijk alle
Small spring and ball fitment (not 3 large springs)
When rebuilding the grinder on my Jura E8, a small spring and ball ‘appeared’ on my worktable. I have been unable to find any reference to them except one video that says put the spring down the center shaft hole which doesn’t work. I would really appreciate a response.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I just received an answer to my question. The small spring is used to index or cause to click, the black toothed gear so that you can count the number of ‘clicks’ when setting up the grinder.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michael Niernberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 269
