Ga door naar hoofdinhoud
Reparatiehandleidingen en -ondersteuning voor de basis inkjet printerlijn van HP, de DeskJet.
106 Vragen Bekijk alle
HP 2512: not feeding paper, rollers aren't moving
My printer is no longer feeding paper when a single sheet is loaded or a stack. It makes a sound like it’s trying to feed the paper, but when I shine a light down into the printer, I do not see that the light gray rollers are rotating when the printer rests them against the paper.
I saw a similar issue (and fix involving epoxy) for a Deskjet that has a horizontal tray, but mine has a vertical tray so I imagine the fix will be a bit different if there is one. Thanks to anyone who has a solution here.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Opened her up with the help of this YouTube video (getting the display panel off was a trick!). https://www.youtube.com/watch?v=rmwYDBrj.... I found a broken off cog (white) and post (tiny black) that I’m attempting to glue back into place. The missing cog caused a disconnect between the other moving cogs and the feeder roller. Fingers crossed here. Also, I cut a window/hole in the back right side of the printer body to access the site. I wasn’t about to take the whole inside apart!
Was dit antwoord nuttig?
Voeg je antwoord toe
Mimy Bailey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 271
