Ga door naar hoofdinhoud
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 Vragen Bekijk alle
My XBOX shuts off after a while when playing.
Could this be an early warning of the RROD? or something else? Also every once in a while the xbox will turn on with video but no sound, or I get sound and no video.
Thanks
Is dit een goede vraag?
1 Opmerking
Does it feel really hot?
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
This is my answer to Another Question:
"This is usually a pre-cursor to the Red Ring of Death, or an e73/e74 error. I suggest installing a Red Ring of Death fix kit, which should fix the problem before it turns into the RROD. Here is a guide that should help you through the process."
And you're right, this is an early warning for the of the RROD.
Xbox 360 Red Ring of Death Fix Kit Afbeelding
Product
$29.99
Was dit antwoord nuttig?
Score 5
This is an indication about how much bad your problem will be.
Your XBOX probably is getting so hot.
In some specialized shops, there are some kits to cool your machine.
Open up the box and clean everything including the fans and heat-sinks; and Replace the heat-sink thermal paste. Dirt, dust and putting the Xbox in an entertainment center are almost always the reason for the red rings in the first place.
I agree with a precursor to the RROD, but with it "not turning on with video but no sound, or I get sound and no video" I would look at the A/V cables. Replace them first, then look at the RROD repair.
Ive got the e71 before on my xbox 360 s
Voeg je antwoord toe
Murmador zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,188
