iPhones X not powering on after battery replacement
Hi, I as doing a battery replacement on my iPhone X. After installing the battery i connected the LCD and Digitizer to test and found it turns on.
I then disconnected the screen again to install a new one.
After installing the front microphone etc on the new screen and reattached everything back to the logic board in order to test and found that it would not turn on. Have tried going back to the previous Screen but that doesn’t turn on as well.
Have tried disconnecting the battery, reseating the connectors and (volume+/- and power for 40 seconds). But no luck.
Any way to check if the device is turning on or if the logic board is faulty?
Is dit een goede vraag?
You could plug it in on your PC to check if it's recognised or doing something.
door koppie007
@koppie007 yes that worked the phone booted. Post boot the device didnt charge so replaced the battery again and it works fine.
door Neil Robinson
Hi Neil,
Alright! Glad that it's working now!
door koppie007
