Ga door naar hoofdinhoud
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
27 Vragen Bekijk alle
boiler does not kick,s on despite pilot is on and thermostat up
i do have W Mclain force hot water system boiler in the house.pilot is on, thermostat all way up and i do have 120V on T1&T2 in relay but nothing happens
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Pressure Switch
The pressure switch closes when the proper airflow is achieved, signaling the control board to continue the ignition process. If the pressure switch is defective, the ignition process will stall, and the water heater will not light.
Thermocouple
The thermocouple detects the pilot flame. If the thermocouple does not detect a flame, the ignition process will stall, and the burner will not light
Was dit antwoord nuttig?
Score 1
1 Opmerking:
this is force hot water system.pilot is on so thermocouple is ok
door
Voeg je antwoord toe
yefim rabinovich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 31
