Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
94 Vragen Bekijk alle
Why is my mac getting really hot to the point its warning me
so while im using word the fan is in between 7000rpms and 9000rpms and while using powerpoint, keynote or just playing gta sa it warn me its too hot
Is dit een goede vraag?
Commentaar:
Install this app to help you isolate the cause of your system overheating TG Pro take a snapshot of the main window and post it here for us to see Adding images to an existing question
door
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
Het nuttigste antwoord
Apple uses thermal paste that dries out in 2-3 years and goes bad at 4 years. If you have never repasted it or cleaned out the dust from the system, start there so you have a known troubleshooting point to backtrack to and can rule this out early. The thermal paste may even be dust with how the machine is behaving.
The guide for the fan can be found here and the heatsink guide can be found here. Try and find Artic MX-4 for this if you can as Artic Silver 5 doesn’t always cure right in laptops, but since this one isn’t difficult to try again on you may want to try Artic Silver 5 on this.
MacBook Air 11" Early 2015 Fan Afbeelding
Handleiding
MacBook Air 11" Early 2015 Fan Replacement
Moeilijkheid:
Gemiddeld
10 - 45 minutes
MacBook Air 11" Early 2015 Heat Sink Afbeelding
Handleiding
MacBook Air 11" Early 2015 Heat Sink Replacement
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Rene Valdez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 36
