Ga door naar hoofdinhoud
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
32 Vragen Bekijk alle
How do I fix my calculator that only runs on solar power?
My Casio fx-991ES PLUS was dropped and now the display does not light up unless it is under a light source. It has a mini solar panel which I assume it using for power and it has new batteries in it but they do not seem to work. Is there something I can do to fix it?
Is dit een goede vraag?
Score 1
1 Opmerking
I replaced mt calculators
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@madrthanevr could simply be an issue of torn wires/ connectors or something more sinister like an issue with the power management IC on your PCB. We’d need to see what is going on inside your calculator Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks @oldturkey03 there was just a disconnected wire. Probably should have checked beforehand. Much appreciated!
door
My casio MJ-12D is not working after putting in sunlight.....what should i do for this??
door
Casio can replace the broken screen, they will give you a price before they do the repair, by the time you add shipping to them and shipping back to you, you will be better off just buying a new calculator and keeping this one for spare parts for the next person who wants to buy a motherboard.
Voeg je antwoord toe
MadRthanevr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 99
Afgelopen 30 dagen: 509
Altijd: 17,983
