Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
191 Vragen Bekijk alle
Will #flexgate reoccur after the first repair?
4-5 months have passed since my Mac started showing symptoms of flexgate. I have made up my mind to pay around $600 to apple service center and repair my mac’s display. But, my question is will this issue reoccur after another 1.5 to 2 years with regular usage ? Or will Apple replace my mac’s display with a display assembly which have a flex cable 2 mm longer than the previous one so that the issue would have less chances of occurring after 1.5 to 2 years ?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
LCD iPhone-scherm fixkits
De goedkope optie, ondersteund door onze levenslange garantie.
Koop kits
Bespaar op reparatiekosten, niet op kwaliteit.
Koop kits
1 Antwoord
Gekozen oplossing
Good question!
Assuming you get the newer longer cable display I’m suspecting you’ll be fine. So that gets into who repairs your system! I would make sure Apple does the work here, and make sure you keep your paperwork.
As far as your systems lifespan thats tricky! So far the 2016 ~ 2018 models don’t have a good record in my option. You’re likely to encounter other issues before your displays backlight fails again.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Arya Kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 111
