Ga door naar hoofdinhoud
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 Vragen Bekijk alle
JBL E45BT name won't appear
hey, i used my headphones as usual in the morning, turned them of, after 1 hour when i wanted to use them again i could not pair it with the phone. i erased all the bluetooth pairs from the phone but now the JBL E45BT name won’t appear in the pairing list. what to do? it turns on as usual,blinking and stuff but the name won’t appear. it’s fully charged. been trying to figure smth out whole day. please helppp
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hold the power slider up for a long time. It'll switch on and then turn off. Worked for me.
Was dit antwoord nuttig?
Score 13
15 opmerkingen:
I had the same problem and that solution worked for me as well. Thank you very much!
door
This worked. Yeeeey. I've been looking all over on how to fix the pairing issue of my headset. Thank you soooo much
door
This also worked for me. Thanks a lot.
door
It worked perfectly, no other reccomendations worked for me besides this. Thank you!
door
yess this worked thank you!
door
10 commentaren meer tonen
Voeg je antwoord toe
Anano Machavariani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 2,881
