Ga door naar hoofdinhoud
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
49 Vragen Bekijk alle
My P20 Pro only has service when plugged into a charger.
I took my phone to a repair shop as i completely smashed my screen.
He managed to replace the screen but now my phone will only connect to Vodafone network when plugged into a charger.
If i remove the usb from the charging port it goes to no service
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like the battery may have gotten disconnected and/or died.
Huawei P20 Pro Vervanging van de batterij
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Changed the battery and still the same issue. Replaced the Antenna as well. Any other suggestions?
door
@jayb_1991
I'm facing the same issue after replacing my battery's
were you able to solve your issue ?
door
Hi, same problem for me. After battery replacement, signal is ok only under charging or if I connect hear jack. Any suggest?
door
Voeg je antwoord toe
jayb_1991 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 469
