Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie voor de Samsung Galaxy J7 Refine, uitgebracht in 2018. Modelnummer: SM-J737PZDEBST.
Incoming doesn't work when WiFi connected.
My phone will not receive incoming calls and texts of I'm connected to WiFi. I've looked through every possible setting in my phone, I refreshed network, I've factory reset my phone. If I restart it, everything will come through and then go back to not getting anything. If I have WiFi off, everything works. I've gotten nowhere with my phone provider, even though contacting them 5 times. I'm at a loss.
Is dit een goede vraag?
Score 1
3 opmerkingen:
Is your SIM card activated? Do you have wifi calling enabled?
door Deel
Yes it's activated, and I have no idea where that is, I'll look though. All my settings for calls are what set to when I factory reset my phone, so I should be good.
door Deel
The only solution is replacement, S9 or 9+. I recently got the 9+ to replace my J7, which was designed to fail within 18-24 month, for sure.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Go to your dialer (phone icon) hit 3 dots in top right corner. Disable wifi calling then restart. Try receiving a call
Was dit antwoord nuttig?
1 Opmerking:
There is no such option in that menu, or when I click settings from that menu.
door Deel
Voeg je antwoord toe
asmith298828 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 283
