Ga door naar hoofdinhoud
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
147 Vragen Bekijk alle
I shattered my screen, and now a portion of it wont respond to touch.
I shattered the screen on my note 8 further, a day after ordering replacement glass for a relatively small fracture it already had. I have a little bit of experience fixing stuff like that and was planning to try to fix it on my own, however now the middle third of the screen is unresponsive to touch. Would replacing the glass fix this, or should i order a new AMOLED?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
if you can see everything on the screen perfectly fine and it’s just the glass that is shattered and unresponsive to touches replacing the glass would probably fix it but it might be much harder than replacing the whole assembly
Was dit antwoord nuttig?
Score 1
Hi @c0nman46
As long as you ordered a quality replacement screen, all of your issues should be resolved with a screen replacement. Damaged Samsung AMOLED screens tend to degrade worse and worse over time until they do not function at all.
I’m hoping that you ordered the screen pre-installed on a frame, otherwise this will be a VERY difficult repair.
Best of luck fixing this up!
Score 1
Voeg je antwoord toe
Con Coster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 47
