eMMC 32GB deleted from BIOS (UEFI with no legacy boot)
I'm using a Acer Aspire 1 a114 - 31. I had similar issue reinstalling Windows 10 and had to format the partitions. The installation using usb bootable windows 10 started working but would stop half way through saying "error, some installation files missing". I tried creating onother bootable, using rufus to convert usb from mbr to gpt in fat32 format all to no avail, the usb was no longer showing up in f12 boot options. I then tried using diskpart to clean the usb and tried again still nothing, then I did same to the emmc 32gb drive (which worked for others with similar problems) which just made things worse because the drive was no longer visible in f12 boot options nor in the bios.
The bios seems to have a crazy limitation; there's just no option to choose between uefi or legacy boot, no bootable devices are visible and I've tried everything, searched and tried different solutions, enable/disabled secure boot, set supervisor password, bios to factory reset but nothing... And no solution out there, seems nobody else has a bios with this kind of limitations.
Now when I power on the system it just says "No bootable device found". PLEASE HELP!
Is dit een goede vraag?
