Ga door naar hoofdinhoud
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
121 Vragen Bekijk alle
Vertical lines on the display?
Hello,
So I have a MacBook pro late 2016 15” laptop, which is almost unused. It was bought 25 months ago.
It didn’t get any external damage - but all of a sudden I got this annoying vertical lines on the right side of my display (and some horizontal ones on the bottom)
I really don’t get it, as nothing really happened other then me opening my laptop as usual.
Please advice!
Thank you very much,
Shy
Is dit een goede vraag?
Een opmerking toevoegen
2 Antwoorden
Het nuttigste antwoord
Hello
If it was me I would connect it to an external monitor
From what your are saying it may be a fault display so I would be connecting an external monitor to it to see i it has the same issue or not
Let us know please
Was dit antwoord nuttig?
Score 1
Commentaar:
Sorry, didn't mention that I connected it to the tv - and it worked fine. So I assume the problem is with the hardware. I also ran a diagnostic and it came out as everything is fine.
door
I leave it now up to the experts here on Macs to take it further There is quite a few so I am sure they will put you in the right direction
door
That's probably a bad display panel, or a bad connection between the display panel and the logic board.
If you don't have AppleCare for the repair to be covered or discounted, then you can take it apart and reseat the display cable. If that doesn't work, you'll likely need to replace the whole display.
Voeg je antwoord toe
Shy Buba zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 17
Altijd: 17
