Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Vragen Bekijk alle
I changed a battery for a customer. screen touches by itself.
So I replaced a battery for a client of mine.
after that she came back (after about 3 weeks). The screen clicks by itself.
From what I know a battery replacement should not do this to a phone, anyone know of a solution?
I did replace the battery three days ago again, since I thought maybe there was a bad battery, she came back now. Same issue.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I believe that would be a bad digitizer module or connection. Try reconnecting the display, then switching displays (if you have a spare).
An iPad I once fixed was worse. When you had the keyboard up it would type random things, even when you leave it alone in a room with no one else. It was like a ghost possessed it.
Good luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I have a battery stand, the customer said she changed screen at someones home before that, so it was solved with a new screen.
door
Voeg je antwoord toe
nicolay.94 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 42
