Kenmore washer won't drain - all mechanical components are working
Hi,
I’ve a 1999 Kenmore washer/dryer combo model 110. Machine won’t drain before spin cycle starts. So when the spin cycle starts the tub is still full of water. I’ve torn this thing down and checked all the mechanical components of hoses, pump, motor coupler etc.
Intermittently it will work and when it does it all seems fine. Does the same thing in all wash cycle options (heavy duty, soak, permanent press etc) I’m focussed now on electrical issues or main control switch panel. Machine agitates and spins fine so I believe I’ve eliminated the lid switch from the equation. Anyone able to offer insight on whats proving to be a challenging fix on an otherwise historically easy machine to work on. Cheers, Larry
Is dit een goede vraag?
What is you exact model number?
door mayer
@mayer thank you.
Model Number: 110. 1850291
Serial Number: MJ3502877
door Larry Sparks
