Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1493 Vragen Bekijk alle
MacBook Pro won’t boot
Hi everyone,
This morning my MacBook Pro wouldn’t boot. I left it on in sleep mode last night as I usually do and this morning it was off.
Upon booting it made three slow and three faster beeps. I tried switching the ram slots as well as unplugging and replugging the battery, which have worked in the past but not this time.
After two attempts it did one long beep instead of the multiple beeps. Now it doesn’t beep and there is no startup tone either.
Currently when I press the power button, the fan turns on (at normal speed) and the front led turns on (at a constant brightness) but there is no startup tone and the display doesn’t turn on. I’ve tried using the keyboard to increase display brightness, no effect. If I close the lid the fan stays on, so it’s not just a display issue. I’ve left it like this for over an hour with no change.
Oddly, when I turn it off, simply inserting the MagSafe connector into the laptop is enough to initiate boot, without even pressing the power button.
I’ve tried booting with Shift, Cmd S, Cmd V Shift, Cmd R, Cmd Alt P R, and SMC reset connecting power with shift ctrl alt.
Ive tried switching the Ram sticks, or booting with just one stick, and I’ve tried both sticks, alone in each port individually.
I also tried unplugging the battery and power cord and holding power button for 10 seconds
Does anyone have any suggestions?
Thanks!
Is dit een goede vraag?
Commentaar:
If you could change the RAM, You do not have e a 2013 MBP Retina. Please insert your serial number from the back of your machine here to find out what you do have: https://everymac.com/ultimate-mac-lookup...
door
Thanks Mayer! Indeed it’s actually a late 2012. I’ve changed the device description above.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Have you tried testing to see if it chimes without the hard drive and battery plugged in with charger connected?
Was dit antwoord nuttig?
Score 2
Commentaar:
I have tried without the battery - won’t boot. Haven’t tried without the hard drive, I’ll give that a go, thanks!
door
Ok I just tried this. Fan whirls, but no chime.
What could this indicate?
door
Try this: disconnect the battery and the mag-safe adapter. Press and hold the power on button for 10 seconds. Reconnect the battery then the mag-safe. You should get a spontaneous reboot. Please ley us know your results.
Score 1
I have a mac book too leaving it on sleep is very risky and shortens the life of your computer take it to the apple store they should be able to fix it
Commentaar:
From what I gather it’s quite common to leave them sleeping, but I’ll look into it..
I’m travelling in a remote part of India and there’s no apple stores here, so I’d really hope to fix it myself
Thanks!
door
Voeg je antwoord toe
Auspicious Tomatillo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 54
