Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
355 Vragen Bekijk alle
My phone turns off after 3 minutes
Im not sure if your able to help, but i have an iphone xs max and i did a charging port replacement pretty easy but the phone stays on for 3 minutes and shuts off battery status seem to be correct everything work it just shut off after 3 minutes what do you think causing the issue and how to fix it
Is dit een goede vraag?
Score 3
2 opmerkingen
I have one doing the same thing it cuts off the powers right back on is this what yours is doing???
door
I changed the screen on mine and after 3 mins mine does the same -.-
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would try to re-install the original charge port to see if the problem persists. If it does, then you may have accidentally damaged something on the logic board (connectors) or one of the flexes. If the problem is not present with the original flex, then you probably have a defective replacement flex.
Was dit antwoord nuttig?
Score 2
Has anyone figured out the fix for this? After charge port replacement i am having same issue
Voeg je antwoord toe
Benny Jelleh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 2,155
