Can't do factory restart
Apps weren’t working, so restarted the tablet but now stuck on the loading screen.
tried to do a factory restart but no matter what option i go to, it all says the same thing
E:/sbin/mkfs.f2fs failed with status 255
e: format_volume make f2fs failed on /dev/block/mnt1b1k_d4voperation not supported on transport end point
E: failed to mount / cache: permission denied
/cache recovery/last_locale
e: can’t mount /cache/recovery/log
can’t open / cache recovery/log permission denied
this a brand new rca tablet. got it like 6 days ago. what do i do now? return it?
Is dit een goede vraag?
3 opmerkingen
unfortunately, i do not have the receipt for mine and am stuck with it. My issue is exactly the same. Is there any way to fix it? Thanks.
door Star 3.0
Have you tried booting the tablet into Safe Mode to perform the factory reset? To boot into Safe Mode, first hold down the power button until the boot menu appears. Then, hold down the "Restart" option until a window appears that confirms if you would like to boot into Safe Mode. Select "yes" or "ok", and allow the tablet to restart.
If it successfully boots into Safe Mode, try going into the Settings app and performing the factory reset.
door Dan A+
i have the same issue and it will not do a hard reset nor will it go into safe mode. It literally goes into fastboot and will not come out of it so i have to switch it off and start again... please help me someone.... i`ve been at this for over a week now :(
door no1screaminskullinhobnailboots
