Ga door naar hoofdinhoud
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
82 Vragen Bekijk alle
My Acer Aspire E15 - 532 Won't Turn On.
Monday afternoon, i went to get on my laptop and it won’t turn on. The charger indicator light appeared but still nothing. I tried the battery reset button but that made matters worse, the charger indicator light isn’t coming on. I’ve tried taking it apart and manually reconnecting and disconnecting the battery, still nothing.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Did you use the main power to power the labtop on?? You seem to be talking like if you are trying to turn it on from the internal battery of the laptop
Was dit antwoord nuttig?
1 Opmerking:
I tried turning it on using the power button.
door
you got to check to see if the laptop is getting power. if it does not get power then pressing the home button will not turn it on
1 Opmerking:
The charger I'm using works perfectly fine in another device. So it might be the laptops power thing.
door
https://www.youtube.com/watch?v=oEQAk2QW...
1 Opmerking:
checking the power jack
door
Voeg je antwoord toe
Com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 2,881
