Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1972 Vragen Bekijk alle
Vraag afgerond
LCD not backlit after replacement
I have recently replaced a broken digitizer and lcd on a 3gs. I was short the new LCD for a few days so I installed the new digitizer with the original LCD that only had a few broken pixels on the screen. It was back-lit for a day of use then the next day the screen stopped lighting up.
After replacing the LCD with a brand new one, Cleaning the connectors, checking the logic board for debris, and running apples 3 troubleshooting steps, the screen is still not back-lit.
any other possible methods I can try to fix this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I'd say check for any loose connections 1st. If the housing itself is causing the backlight function to stop, it could be something more internal with the LCD/digitizer.
I'd say the digitizer must be replaced as a (whole unit together -LCD and digitizer together) as it looks to be damaged based on your point that the back-light does not work or stops functioning when pressure is applied.
By the way how did you repair those brass clips that were bent? Can one find replacements?
Look forward to your reply..
Good luck
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 749
