Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
409 Vragen Bekijk alle
Why does my xbox turn off after 1 minute with no display?
I started my xbox one up one day and it only stayed on after a minute, nothing on the display showed up and my controllers refuse to pair with their blinking light showing. Even holding the sync button on the xbox doesn't do anything. My fans are spinning. The only thing that sounds out of place maybe is that the hard drive makes a noise every 20 seconds like it suddenly stopped and started again. I opened it up and removed all dust inside which were minimal amounts. Any ideas?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
These usually come with a Seagate Mobile HDD, these commonly go bad after 1-2 years. If it’s making a ticking pattern the hard drive will need to be replaced. One way to confirm it’s the HDD is to just plug in any 2.5” laptop sized hard drive and see if you can get display at least.
Here are the two guides required for replacing the HDD on the One S:
Xbox One S Hard Drive Replacement
Install firmware on Xbox One S
Xbox One S Hard Drive Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
Xbox One S Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
30 minutes - 1 hour
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
That was it, thank you!
door
Anyone in the future who might have this problem, my hard drive ticked once per second when it was trying to boot. I switched it to a laptop hard drive showed the display and switched it back to my old hard drive and booted up fine, guessing it's a sign to get a new hard drive. Thanks man. You saved my week head ache and a lot of money.
door
Exactly what i was dealing with. thanks for sharing the question and thanks for the answers.
Voeg je antwoord toe
Michael del zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 822
