Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
20 Vragen Bekijk alle
WIFI on iPhone X isn't working after screen replacement! HELP!
The iPhone X was working fine and no issues with the wi-fi. I put the new screen on and now there are no WiFi networks showing up!
I’ve checked the antenna at the bottom of the phone and that seems fine. Everything else works including the audio without any issues!!
Thanks
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
When you replaced the screen did you make sure to connect everything back again before assembling it back?. I would suggest you to do it again since there might be something in there that is not quite right. If the antenna is connected, disconnect and re-connect it back and try again. Before you do this, try resettings the network settings on you iPhone and test it again. If this does not work for some reason then try to check the antenna again.
Cheers!
Was dit antwoord nuttig?
Score 1
What was the solution?
Voeg je antwoord toe
Rc Noobs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 2,029
