Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
iMac shows the blinking folder after replacing with new SSD
I have replace my IMAC hard drive using ifixit kit with a new SDD. Followed directions precisely. When I start my computer I get the folder with question mark…? I can do “Option” and get the option to boot from a bootable usb I’ve made. When I select that it just goes to the zero with slash through it….? What is up with this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The slash is telling you the USB drive is not a bootable macOS for your system the highest this system can support is 10.13.x High Sierra. Is this the OS you setup the USB drive with or one this is older? If not you’ll need do that.
What is the SSD you installed make and model? Your system needs a SATA II (3.0 Gb/s) drive. Most drives being sold today are fixed SATA III (6.0 Gb/s). You’ll need to get an auto sensing drive like a Samsung 860 EVO which supports SATA II as you can see here in the specs sheet https://www.samsung.com/semiconductor/gl...
Was dit antwoord nuttig?
Voeg je antwoord toe
wes.hamilton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 35
