A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
3 opmerkingen
Rarely does a cap go on its own. There is often a cause are you sure you are not fixing the symptom and not the root issue here?
How about giving us some background. Apple has a few extended warranty programs for your system (I think there are five now). So before you start altering things it may make sense to see if there is an issue you can claim to get this fixed for free.
I purchased the device in late 2016 in the UAE and the machine worked wonderfully. About three months ago the device was in stand-by mode and I did not use the device for two days and when I tried to start it did not work the device. I thought the reason might be the battery and already changed the battery and the operation of the device but there was a depletion of the battery was discharged quickly to turn off the device after three days and did not work. I opened the device to see what the problem and found this piece in this way
3 opmerkingen
door Dan
Thank you for your quick response
door ammar_m_ali
Did you check to see if this was valid? 13-inch MacBook Pro (non Touch Bar) Battery Replacement Program and get it fixed under it? There was a parts issue also involved here.
door Dan
