Ga door naar hoofdinhoud
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
My Ipad won't get past the Apple logo.
So I replaced the LCD ,Touch digitizer and home button and when I plug in the charger, the screen shows the Apple logo and then turns off and repeat over and over again and .I don't know why, the battery has not been charged in a long time, like a couple months so that could be the one of the problem ‘s but please help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Presumably you changed all of these parts because the iPad took some physical damage. Was it working properly right up to the screen damage? If it was, then either you have a defective replacement part or you damaged something during the repair (or incorrectly connected things).
Double check your work and if the orignal parts still work somewhat, try them to see if the problem persists.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Troy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 106
