Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
782 Vragen Bekijk alle
Ps3 won't turn on. Beeps 3 times. No red/yellow light flashing.
So, I tried to turn my ps3 on this morning and I noticed that it would not power up. I decided to unplug it but still had the same problem. I flipped the switch in the back to the off position and then back to the on position. Thats when I noticed that the "RED" light that indicates power to the unit was not on. I have tried to to turn the ps3 on numerous times with no success. The only thing that happens is the console beeps 3 times and then it shuts down. There are no RED or YELLOW flashing light... It just beeps 3 times and then it shuts down. Does anyone know what the problem might be? Or if there is a quick fix. Your input would be greatly APPRECIATED!!!
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Sounds like it's either the power supply or the motherboard. Unfortunately, diagnosing exactly what part of the motherboard is bad is a very difficult task, and if a new power supply doesn't fix it, you would probably be looking at an entire new motherboard.
PlayStation 3 Power Supply Afbeelding
Handleiding
PlayStation 3 Power Supply Replacement
Moeilijkheid:
Gemiddeld
20 - 25 minutes
PlayStation 3 Motherboard Afbeelding
Handleiding
PlayStation 3 Motherboard Replacement
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
I just had this problem turned out it was the small mother board in the controll switch (on/off , eject disc )
I had the same exact problem but the problem was just the HDMI plug wasn't plugged all the way in. Heyyy, problem fixed!! U can call me Ayhaunna the Fixer!! (Bob the Builder) u get it?? No?!, ok!...have u a good day u guys
Just had a fat PS3 come in to X MARX THE BOX for this. No flashing lights but instant 3 beeps and light stays red. Pulled it apart for the customer and what they thought was a overheating issue was much worse. Liquid damage(soda) and it bridged 6 of the SATA pins, possibly from heat, on the board. Heat and liquid are the main killers and this is the second fat PS3 I've had in this year with liquid damage. The first had corrosion eating the connections so I cleaned it all up and got it running but it failed again but much worse within a few months. That one had at least 20 circuits damaged but this one may be able to be microsoldered to fix the issue. Always put your PCs and consoles in elevated and well ventilated areas and NEVER set drinks or liquids within a arms reach of them. Lost my Atari 2600 in 1985 because I used to set my milk on it but the Atari wasn't thirsty. Good luck.
Voeg je antwoord toe
Sleepy Will zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 64
Altijd: 21,813
