Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 Vragen Bekijk alle
Replaced Power Supply Still no Power
I replaced my power supply because i dont even get a red power light and its still not doing anything. What else could it be?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Jared, give this a try. Of course triple check your work first. make sure that all your connections are snug. Hope you got a multimeter as well
1 – Check for loose cables.
2 – Take out all cables and plug them back in.
3 – Try to take out your HDD drive. Once it’s out, put it back in again.
4 – Restart your console.
Here are the Level 3 service manuals for the PS 3.
Part 1
Part 2
Part 3
Part 4
They will show the layout of your logic boards as well as a parts list. Trace your power supply and see if it is a component on the power circuit that has failed. Good Luck and let us know if and when you get it narrowed down a bit.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ really nice answer, as usual
door
+ Good share OT03, I hope you don't mind if I call you that. I caught this off of an earlier posting and it helped my put together a system that I had my time into, but no money into, with a bent motherboard and damage on several layers of the MB. Very few "manuals" are as detailed as these are.
door
well that could be the motherboard and will need to be replaced
Voeg je antwoord toe
Jared zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 895
