Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
CPU fan running at full speed while fan control shows 0 rpm
Hello there guys,
So I've recently baked my GPU and it works like a charm, but during the process I accidentally ripped my GPU thermal sensor cable.
I've plugged loose sensor cable back to the board, but it is not attached to my GPU.
Now ever since my CPU fan is running at full speed but fan control software shows my CPU fan running at 0 rpm without any option to control it (I can control ODD and HDD fans though).
I have tried resetting and upgrading my SMC, tried upgrading EFI as well without any luck.
My question is does lack of my GPU sensor affect my CPU fan or the problem is elsewhere?
Thank you for your time!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Simple answer - YES!!
What you are seeing is SMC has gone into Safe Mode to protect your system from overheating. When any thermal sensor becomes disconnected this is what happens.
You’ll need to fix the GPU thermal sensor.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
krauut zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,183
