Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
464 Vragen Bekijk alle
stuck Y screw for battery hold er
I bought a replacement battery for my 2012 15” mbp, took off the back, then set about taking out the battery with the Y screwdriver. But, I couldn’t get either of the screws to turn. I stripped one of them (gave myself a dope slap), but I cannot figure out how to get either of the screws out. HELP, please!
Is dit een goede vraag?
Een opmerking toevoegen
PC Laptop Batteries
Batteries for all the top PC brands, backed by our Quality Guarantee.
Nu winkelen
PC Laptop Batteries
Nu winkelen
1 Antwoord
Het nuttigste antwoord
When it happens to me I usually cut a slot in the screw head with a dremel like cutting disk. Otherwise you may break some of the plastic under the screws, remove the battery and try unscrewing with a nipper.
Was dit antwoord nuttig?
Score 3
Commentaar:
I don’t know if any nipper type tool will be able to break the screws loose. It almost feels like some idiot crazy glued them in. Most screws I find in computers are firmly seated, but not frozen in place, so I’m at a loss. The battery on this mid-2012 mbp is supposed to be changeable. I’m just wondering if somebody in the assembly process didn’t read the memo.
door
As @arbaman arbaman stated break the plastic around the screws. Use a pair of dikes to snip the little plastic extension loops. Then you can remove the battery and get a pair of pliers on the screws. These tabs are very easy to break and I usually see they are already broken in about a third of these machines.
door
@mayer Pliers is the word I was missing :)
door
Voeg je antwoord toe
George Beltzhoover zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 10
