Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
464 Vragen Bekijk alle
Why does my MacBook Pro have no audio devices?
My MacBook Pro 2012 15in does no seem to have any audio devices. I’ve changed the speaker, tried reseting the pram, and going into system preferences. However, nothing has worked.
Edit: Forgot to note that the audio works if you put a pair of headphones in.
Edit 2: It doesn’t work with headphones now.
Is dit een goede vraag?
Een opmerking toevoegen
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Nu winkelen
iPhone X Fix Kits
Nu winkelen
2 Antwoorden
Het nuttigste antwoord
Look in the port when the jack is out and tell us if you see a red light, please.
Was dit antwoord nuttig?
Score 2
Commentaar:
Sorry about the delay. I do not see a red light.
door
Also I just found out that it doesn't work with headphones now.
door
@bsellner - Then you likely have a messed-up jack. Within the jack are two leaf switches as you can see here:
What can happen is the contacts for the internal speaker don’t connect after you’ve removed the plug. using a dental probe see if the contact is making contact correctly.
Score 1
Commentaar:
I forgot to mention that the audio does work when headphones are put in. I can get headphones in and it the audio comes back.
door
Voeg je antwoord toe
Ben Sellner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 36
