Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Vragen Bekijk alle
White screen after thermal paste changed
Hi there, My problem is this:
My MacBook Pro 15” Mid 2012 was fine everything worked normally.
Yesterday I changed out battery with a new one and I had an idea to change the thermal paste, I removed all screws as shown in tutorials, removed the logic board changed the thermal paste, assembled everything back to there places and powered on the system and here is where I’m stuck! Greeted with a white screen!
I hear the chime of powering on but nothing shown in the screen just a white screen
I removed the RAM , the SSD did all sort of resets, but nothing still a white screen
Any suggestion ???
Thanks in advance
Is dit een goede vraag?
1 Opmerking:
The thermal paste was a cooler master
I will take the Logic board out again and see what will happen
door
Voeg een opmerking toe
1 Antwoord
If you can plug in an external display to see if that works.
If it doesn’t work then the issue is clearly something within the logic board that’s messed up. What was the thermal paste you used? You may need to take the logic board out again to check the application of the paste. You don’t want paste oozing off the chip surfaces onto the green sub-straight as you can interfere with the SMD components on it
Could you have damaged something in the process of taking the board out or putting it in?
Was dit antwoord nuttig?
2 opmerkingen:
Ok i did a tear down again , but the same result a white screen
door
Sorry to hear that ;-{
Compare your logic board against the a good one or a set of high def pictures to see if you can see if a component got knocked off. Otherwise you'll need to get a new board.
door
Voeg je antwoord toe
ismail hadji zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 156
