Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Won't charge, any ideas?
Hi,
iPhone 3G stopped charging, but speaker and mic works ok. Swapped the dock connector / speaker assembly for an old one which had a duff speaker. Phone charged fine. Tried 2 x brand new dock connectors but just getting sound but no charging.
Why would it work with one dock connector but not the other?
All screws are in place bar the two in the bottom of the phone, all connectors are in place securely
It's driving me mental now!!!
Is dit een goede vraag?
2 opmerkingen
Hi thanks for your answer. Wha bit exactly would I resolder? Would it just be take off the no 4 ribbon cable and dock itself? A total of 4 things to unsolder and resolder?
door
only the speaker portion from connector 4 on the dock connector.... as the speaker is housed inside the dock..(it's the 2 solder points above J3)
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I'd desolder the known working charger/dock port from the duff speaker and solder it to the good speaker. Then what does it matter? problem solved.
Was dit antwoord nuttig?
Score 1
All working now. Cheers mate
Voeg je antwoord toe
Kris Ackrell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 286
