Galaxy J7 Prime turns off if shaken
After a screen replacement my Samsung Galaxy J7 Prime turns itself off if I shake it a little bit, while I’m driving my phone turns off and wont turn on until I connect the charger and then press the power button, I suspect that my Battery is loose but I don’t see how it would be possible since the J7 Prime battery is very well kept inside a metal cage with 16 screws. Any suggestions?
Edit: The only way I found to fix it was changing out the battery, it wasn’t loose apparently but it was a battery problem.
Is dit een goede vraag?
1 Opmerking:
Follow up: I glued some tape into the battery to prevent it from shaking, it's a little bit better but the phone still turns off if I put it in my pocket
door
Voeg een opmerking toe
