Display has an issue with lines
I have issue in Macbook air 2017 13inch laptop the display was showing completely black and I have reset the NVRAM and it did not work. After pressing a little on the sides of my laptop I got the see my display with many lines.. when a little pressure applied on key the brightness of the screen changes.. I have shared the image of current display state.. kindly help me on this.
Is dit een goede vraag?
6 opmerkingen
Is the display its self damaged?
Voeg afbeeldingen toe aan een bestaande vraag
door Dan
I hope you didn't squeeze the display because if you did, you may have just damaged the LCD display panel.
Applying slight pressure on the screen is ok to see if marks appear which would indicate screen + backlight is turning on but no image is being produced.
Might want to try one of the display outputs from the side of the MacBook I think it's mini displayport so you will need to use an adapter if you want to plug HDMI in.
door Ben
@benjamen50 I haven't applied more pressure on the LCD display.. I just pressed mildly the black part and the nd the backside of the keyboard area mildly.. previous it was completely blank and now it came to this level.. I have shared the images also
door Fazil
@danj no damage happened to the display .. i got grey screen with lines when I was working on the laptop suddenly..
door Fazil
I have the exact same problem. No damage to display. Started it one day and there it was. External screen works fine. Mac book air 2017.
door Petter Bjelm
1 commentaar meer tonen
