I have no picture but I do have audio
Visio E701i-A3
Hello how are you guys I need help I'm having the same problem I have no picture but I do have audio it's the same TV as Brent i did changed the T con but I still dont have picture at all so I'm wondering how can I test the power voltage but what could I be I don't know if you guys can show me.with picture how to measure the voltage on the power board
Update (06/23/2019)
Here is a picture
Update (06/23/2019)
You mean this two ?????
Update (06/23/2019)
I tested the power voltage here is the pic I'm getting 3.38 here I will add the picture
Update (06/23/2019)
Here is another pic I unplugged the power supply from the wall and I dont get stand by voltage is that normal here is a picture
Update (06/29/2019)
Hello how are you @oldturkey03 so here I have some pictures of the boards
Is dit een goede vraag?
12 opmerkingen
Ok today I will take some nice pictures of all the boards thank you so much @oldturkey03 I really appreciate the help thanks so with the pictures you will be able to pointed out were should I resoldering????
door victor galeana
Check the bottom of the boards where the connectors are soldered to. Sometimes a simple resoldering of those contacts can help.
door oldturkey03
as well as the one to the right of those and the one below that
door oldturkey03
You think it could be the power supply board or not at all ???
door victor galeana
It's a Vizio so anything is possible. Personally, I think it is less likely and I would check the voltage from power board to main board. I am leaning toward the main board or the panel (hope not)
door oldturkey03
7 commentaren meer tonen
