Ga door naar hoofdinhoud
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
MBP boots with press on any key? Can't do SMC.
Is this normal? This way it seems I can’t do an SMC, because any press on a key will start up the MacBook Pro. How do I do an SMC on this MacBook Pro?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Wherever you are in the world you should just head to Applecare, either online or in a local store. What you are experiencing is not normal at all and will most probably lead to a Mac replacement.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
This is normal. The Mac is designed to auto start when you press any key.
Just hold down Shift+Option+Control when the laptop is off for 7 seconds. It will turn on. After 7 seconds keep holding the keys down and additionally press the power button (Touch ID). The laptop will turn off. Wait a few seconds then turn it on normally, and your SMC should be reset!
See: https://support.apple.com/en-ca/HT201295...
Score 4
Voeg je antwoord toe
Kurt Vandeweerdt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 11,019
