Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1200 Vragen Bekijk alle
iPhone X diagnosis device won't turn on
Two weeks ago my IphoneX just died while I was charging it. I did the reboot steps but didn't work. I connected it to the itunes but it still did not work. So, I went to the apple service center to get my phone checked. They said that my device won't turn on and the reason behind it is because of the logic board or the motherboard of my iPhone is damaged. AND they can't do anything about it or fix it. All they can advice to me is to get a new one or a replacement phone which costs about $780 because my warranty is expired. My phone is already a year and a half old. I MEANNN come on. I’m so frustrated right now. What should I do?? My phone was working really well before the incident.
Is dit een goede vraag?
3 opmerkingen
Please do tell me or share anything if you have kind of the same experience.
door
Will happen from time to time, Look at local facebook marketplace for cheap repairs, Good thing about todays time is a lot of people to repair phones and help you. You're device is already out of warranty so wont have to worry about on that side.
door
Thank you for your comments. You guys are very helpful.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The problem with cheap places is that they are cheap for a reason, look for someone good and reputable that is able to repair the phone for u...
A bad cable or bad charger can cause what ur describing, look for someone reputable that is good at their job and tell them everything exactly what happened to the phone, if it was dropped etc if it was charged on a dodgy charger etc and they should be able to fix it for u. Take it somewhere that doesn't specialise on these kinds of things just because it's cheap then ur likely to loose ur chances of being able to fix it and places that can may charge u more because it's been tampered with
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I agree with C here..."cheap repairs" and "iPhone X" don't go together. It is an extremely complex device to repair and cheap places will probably kill your device more than anything else.
door
Voeg je antwoord toe
Gee Lyn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,458
