Ga door naar hoofdinhoud
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
64 Vragen Bekijk alle
Why when my phone rings it makes my notification sound
Hi I have a Samsung J8 and my problem is that when my phone rings instead of hearing my ringtone I hear my notification sound. I tried almost everything and nothing is working so if u have a suggest can u plz help me
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
are you able to hear music/ sound when watching videos? if you aren’t able to then there could be a problem with your speaker and that will have to be replaced. if it does work then there could be something going on in your settings if you go to settings then sound you can find the setting there. If that still doesn’t fix the issue I would backup your phone then do a factory reset.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you so much. The factory reset worked. Thz ❤❤❤
door
glad to hear, you're welcome.
door
Voeg je antwoord toe
Kelaiah Latchman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 451
