Stuck on apple logo, now fully shorted
<- do you think this micro crack can be the issue ?
Hi,
I´ve got iphone 7 plus which was stuck on apple logo, power consumption was 0.80a and occasionaly jumped to 1.5a for a split second.
I left it like that for 2 minutes to see if it will eventualy boot up.
Unfortunately phone died and went to the full short after that and PMIC is extremely hot .
Should this cause PMIC to fail or most probably that is some cap shorted anywhere else without the heat coming out of it ?
I want to make sure before I pull anything from the board.
thanks
Is dit een goede vraag?
1 Opmerking
We will need more info. You say it went to full short. Did you determine this from your ammeter? First diode mode VDD_Main or hook up a dc power supply and see if it is drawing current before prompt to boot. If it is a VDD_Main short I doubt it would be the PMIC it could be a capacitor or IC. Just because something gets hot doesn’t mean it has a short to ground.
door Chris Stables
