Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
My install kit did not come with an iOpener. Do I have to buy one?
My iphone 7 plus battery and install kit did not include an iOpener. Do I have to have one or is there another method to loosen the adhesive?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Use a hair dryer judiciously. Hubba-hubba - keep it moving!
Was dit antwoord nuttig?
Score 1
What it did come with is tweezers and a spudger im sure.
Use this guide to get the battery out: iPhone 7 Plus Vervanging van de batterij
Loosening the adhesive under the bottom is only going to make it more want to snap more. If you would like to try it without the I opener, use a hairdryer. It works just as well as the iopener or heat gun. Also if the adhesive breaks. Go under the battery with the spudger on the flat side not the point side. Be very carful to not puncture the battery and work your Spudger up the battery. Another way to get it out is to Lift the battery a little and grab the white adhesive with the tweezers and spin the adhesive around the tweezers and pull the rest out to finish the job. I hope this helps.
Score 1
That’s great, but 1) the instructions on the page specifically state use the iOpener, and there are other less expensive options out there that also do not have an “iOpener”.
Voeg je antwoord toe
Donna Hall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 118
