Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
713 Vragen Bekijk alle
I have a general wiring question about ignition wire harness?
I am actually working on a dixon ztr 308 zero turn mower and am wondering if I have to use a wire harness to connect keyed ignition switch or if I can wire strait from ignition to solenoid, magneto, and ground? Is the harness just for a quick disconnect?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Thank you for the confirmation all the wires were corroded and direct wired now with better quality wire. Runs great now
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
A harness is for consistent easy assembly at the factory. You can direct wire with a connector or not. The ZTR 429 I’m rebuilding wouldn’t engage the blade clutch, the connector was so badly corroded. I bypassed it using wire nuts. Now waiting on new drive cones to finish the rebuild.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Wesley Neal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 21
