Clutch failure - As if drum is jammed.
Replaced the clutch/pulley 5 months ago.
Now, the motor stopped turning. Diagnosed as motor controller. Replaced the controller motor turns again. Put belt back on pulley and tested everything. It made an awful clicking noise. Shut it all down and diagnosed bad clutch.
1) The internal clock spring is ruined (the clicking noise).
2) I can turn the center shaft of the drum, but not the outer parts (agitator?)
3) Need yet another new pulley… $210 Not worth it, but I still want to know what went wrong.
Did I install the original clutch wrong? Belt too tight? Pulley bolt too tight?
Is dit een goede vraag?
@smirk what exact model is your Whirlpool washer?
door oldturkey03
Its actually a Maytag Neptune FAV9800A - same internals as whirlpool (all the parts were whirlpool numbers.
door Dirk
