No backlight on MacBook Pro 13", 2015. Fix or buy a new one?
Hi!
The display on my Macbook Pro 13” 2015-model have been flickering the last couple of weeks, but after starting it up after an updating last night the flickering worsened before the screen went completely black. But the “starting”-sound works, and so does the keyboard and touchpad, but the backlight on the keyboard have been working some on-and-off.
We do not have Apple Store in my country, Norway, but I went to some authorised Apple distributor/repair here. No one listened more than the display being black, and concluded that the display was broken and the hole thing had to be changed, which would cost $840. Not happy about the help I received, I researched myself and found out that the problem is the backlight, so the problem will be connected to the logic board. No one will not give me a price estimate on changing the logic board/components on the logic board, and I fear it would be pricey.
So I have a couple of questions.
1) Have any of you changed/fixed the logic board on your macbook, and what was the price? - My parents are traveling to the US, so fixing it there is an option.
2) Would you choose to change/fix the logic board or just buy a new macbook pro if it was you? The Macbook had the most upgraded specs at the time and did cost $2700. But the battery, only had 400-500 charge cycles, already have to be changed. A new Macbook Pro with wanted specs would be $3150 here in Norway, but buying it cheaper, at “only” $2499, in the US is an option. - Only different is that we have 5 years warranty in Norway, but most of the time they will say it falls outside of the warranty. I am hesitant to buy the new Macbook Pro with the problems it have had with Flexgate and the keyboards.
Is dit een goede vraag?
1 Opmerking
I decided to go to a unauthorized repair shop in Norway today. He opened the Macbook with me there. We found liquid damage by oil. So luck there as oil apparently is better then water. The liquid damage we found was very little, so he found it odd that it was the reason for the backlight not working, but he concluded that the liquid damage was the reason for the keyboard backlight to be on-and-off that one time. He cleaned the logic board were it was liquid damage. He then tried the now clean logic board on another screen and the backlight worked just fine, but back in my macbook the backlight still didn’t work. He believes it to be liquid damage on one of the connectors on one the cabels that goes from inside the screen and to the macbook.
door Mia Løvlie
