Ga door naar hoofdinhoud
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
72 Vragen Bekijk alle
Can I replace a AW3 GPS display with a AW3 LTe display
I have a AW3 -GPS version with broken touch and access to a good display from a AW3 LTE version.
Can I use the AW3 LTE display to replace the AW3 GPS version??
Or can i buy a digitizer for AW2 and use it to replace the one broken on the AW3 GPS version
TY.
Is dit een goede vraag?
Score 1
Commentaar:
I wouldn’’t recomend it.
door
Hi, can you elaborate ?
door
Een opmerking toevoegen
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Nu winkelen
iPhone X Fix Kits
Nu winkelen
2 Antwoorden
Het nuttigste antwoord
The Apple Watch Series 3 GPS version is a different model from the LTE version. The screens for these two models are unfortunately not compatible with each other.
Was dit antwoord nuttig?
Score 1
This should work fine. There isn’t any difference in the digitizer from AW2 vs AW3 - also between GPS and LTE.
Voeg je antwoord toe
Sohorca Adrian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 13
Altijd: 46
