Ga door naar hoofdinhoud
Reparatiehandleidingen voor je muis, die je cursor rondbeweegt op het scherm.
481 Vragen Bekijk alle
Why is my mouse's right click sometimes doesn't work?
I have a Acer Predator Cestus 300 mouse that I’ve used for 6 months since. Recently, it’s right click seem to be broken: sometimes when I press it does have the “click” sound but it does not work. When it happens, I have to kinda press it harder to make it works again normally but I worry if I continue to do this I will brake that right one.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi hongminhau2011
Sadly those micro switches have some lifespan….
I had fixed a lot of mouse due to this issues…….
You will need to open up, and check on it, lookout for any dry solder joints too.
If you have some soldering skills, considering replacing the microswitch first.
You can source it from ebay / aliexpress.
considering sharing the internal pictures of your mouse.
Was dit antwoord nuttig?
Score 1
the button on the right is very floating with the design itself there is a problem because the right mouse button hangs all over the middle dividing point and when you press it, it clings to it, so it's weird to click on it. It can slowly break down unfortunately.
Max can use the right click to move it at an angle of 30 degrees, not vertically, then click well ... just paying attention while watching this game is impossible.
In Hungarian / Magyarul
a jobb oldali gomb, nagyon lebegően van kialakítva maga a formatervezéssel van probléma, mert rá lóg a középső osztópontra az egész jobb egérgombja és amikor nyomod, akkor ahhoz szorul hozzá, ezért fura klikkelni vele. Lassan tönkre mehet sajnos.
Max úgy lehet használni a jobb klikket hogy az 30 fokos szögben mozgatod rajta, nem pedig függőlegesen, akkor jól klikkel...csak hát ezt a játékot közben odafigyelve képtelenség.
Voeg je antwoord toe
hongminhau2011 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 821
