Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Released September 22, 2017. Model A1863, A1905. Available as GSM or CDMA / 64 or 256 GB / gold, silver, and space gray.
437 Vragen Bekijk alle
Screen change keyboard don't show up
Okay, here is the weird situation.
I changed the screen of an iphone 8, everything works perfect, customer came back, he cannot edit or add contacts because the keyboard wont show, but on everything else keyboard pops up.
Anyone know what this is?
I suspect a software issue since keyboard is showing every where else.
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
1 Antwoord
Het nuttigste antwoord
Try a hard reset first (See: Comment forcer le redémarrage de l'iPhone 8)
However I think you are correct, a software fault is the most likely cause of this and that would be fixed via an update/restore.
Is the customer on the beta program? A friend of mine is and he could only answer incoming calls, his dialer wouldn’t work until the following update was available.
Was dit antwoord nuttig?
Score 1
Commentaar:
Actually thanks for this, but it was me having a mayor brainfart.
I just had to double click the homebutton and exit all programs.
door
No worries, if only all fixes were that easy!
door
Voeg je antwoord toe
nicolay.94 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 33
